LSiegel
I’ve been trying to overwrite the Sort By select for the sort filter on this page, but css isn’t working. Do you have a solution? Specifically want to add a gap before the drop down and radius on dropdown border to start.
George
The main issue is the <style> tag on the page has a syntax error — the opening tag is missing its closing
>:<style .facet-sort { border: 1px solid #143677!important; padding: 8px!important; border-radius: 12px!important!important; } </style>Because the tag is malformed, the browser never parses the rules inside it. There’s also a double
!important!importanton the border-radius line, which is invalid.Beyond that, native
<select>elements won’t honorborder-radiusin most browsers without resetting their appearance first. Try targeting the actual FacetWP sort select like this:.facetwp-facet-sort_by .facetwp-sort-select { -webkit-appearance: none; -moz-appearance: none; appearance: none; border: 1px solid #143677; border-radius: 12px; padding: 10px 36px 10px 14px; margin-left: 10px; background-image: url("data:image/svg+xml;utf8,<svg xmlns='http://www.w3.org/2000/svg' viewBox='0 0 12 8'><path fill='%23143677' d='M6 8L0 0h12z'/></svg>"); background-repeat: no-repeat; background-position: right 12px center; }The
margin-leftgives you the gap before the dropdown, andappearance: noneis what unlocks the border-radius. -
LSiegel
Thank you George – I removed the on page styles shortly after submitting this. Tried the style suggestion you provided, but no luck. Thanks so much for the suggestions.
This is how the Sort By select currently looks on my end:
I’m not sure if that already matches what you’re aiming for, but if not, what other changes are you trying to make?
LSiegel
It is the Sort By when expanded – trying to add radius to border and a margin/gap at the top to get closer to the drop down style under Filter by
Ah okay. Unfortunately, this isn’t something that can be achieved with CSS alone which is why it is not working.
The
Sort ByandFilter Bydropdowns are implemented differently. TheFilter Bycontrol uses a custom dropdown component, which gives full control over how and where the options panel is rendered.The
Sort Bycontrol, on the other hand, uses the browser’s native<select>element. When that is opened, the browser (or operating system UI layer) determines how and where the option list is displayed. That behavior is outside of the page’s styling layer and can’t be reliably changed with CSS. -
LSiegel
Thank you
No problem!
