Fade out option
  • Hi Team!
    In the original sample template, there is a fade-out kind of look available.
    I struggle to recreate it even though I have reviewed the source container in detail. I tried to copy it as a whole but the effect is not carried over. Where that setting might be stored? Please look at the sequence of pictures:
    1. Pic with fade out
    2. Container with fade out effect
    3. Pic without fade out
    4. Container without fade out effect
    https://imgur.com/a/56EfoWl
    The template is Coach.
    Best regards,
    Tadeusz
    I don’t see a fadeout effect on the Caoch template. can you explain some more?
  • Hi Ying!
    Could you please look at the second and third photos – you would see that the color from the menu is sort of blurred going down, while on the other picture, there is a clear border where the white begins.
    I may have named it incorrectly; apologies.
    Best regards,
    Tadeusz
  • Oh, you meant gradient. Sorry, I couldn’t understand what you meant by “fade out” earlier.
    It a gradient background attached to the root container:
    https://app.screencast.com/yebjJP7qHYsjb
