Tim in Seattle
Is there a way to set “fallback content” for a Dynamic Tag? For example, using Post Meta for an ACF field, if that ACF field is empty, rather than hiding the field by default, the “fallback content” would show. A good use case example would be having a “custom-cta” field for the text of a button that falls back to “Learn More” if a custom CTA is not in the field.
Hi Tim,
There isn’t a built-in fallback option for dynamic tags yet, but you can add one with the
generateblocks_dynamic_tag_outputfilter. This PHP snippet returns “Learn More” whenever thecustom-ctafield is empty:add_filter( 'generateblocks_dynamic_tag_output', function( $output, $options ) { $tag_name = $options['tag_name'] ?? ''; $key = $options['key'] ?? ''; if ( 'post_meta' === $tag_name && 'custom-cta' === $key && '' === trim( wp_strip_all_tags( $output ) ) ) { $output = 'Learn More'; } return $output; }, 10, 2 );Let me know if this helps!
Tim in Seattle
Thanks @Ying. That solution works. I like how you said “yet” in your response. A fallback option definitely seems like a good feature for GenerateBlocks Dynamic Tags.
