Fatal Error Memory Exhausted when using Advanced Excerpt plugin
    I installed the Advanced Excerpt plugin (https://wordpress.org/plugins/advanced-excerpt/) to be able to use html in excerpts.
    After activating it, I started getting the following error when trying to edit pages containing query loops with excerpts:
    Fatal error: Allowed memory size of 536870912 bytes exhausted (tried to allocate 12288 bytes) in /home/*****/*************/wp-content/plugins/generateblocks-pro/includes/defaults.php on line 60
    The error takes place just after clicking on “Edit” from the “Pages” section.
    Thank you
    I activated the same plugin and did not encounter this issue in on a page with multiple query loop blocks.
    Does the issue occur with all plugins disabled except for GenerateBlocks and Advanced Excerpt?
    Can you try increasing the PHP memory?
    yes, it also happens when all plugins are disable.
    Tried to increase memory to 1024M but I still get the error.
    Thank you
  • WP version is 6.5.5
  • yes, it also happens when all plugins are disable.
    Do you mean you still see the error when the GenerateBlocks plugin is disabled?
  • No, I still get the error when all plugins are disabled except for GB, GB Premium and Advanced Excerpt.
    I also tried to revert to Twenty Twenty Four Theme.
    Thank you
  • Have you successfully edited an excerpt after installing the plugin?
    Or the error shows as soon as you want to edit a page with query loop?
  • Yes, I successfully editet an excerpt after installing the plugin.
    It happens as soon as I want to edit a page with query loop, but only if the page contains the “Excerpt” block in the query loop structure.
    Thank you.
    it’s an issue with the Advanced Excerpt plugin being used inside Blocks within a query loop.
    See here for the plugins author reply regarding that:
    https://wordpress.org/support/topic/advanced-excerpt-in-wordpress-querry-loop-block/#post-16653037
  • Ok, I’ll solve in another way for the moment.
    Thank you
  • You’re welcome
