Anonymous
Hi There,
I’ve implemented a gallery which will displayed instead of post featured image. By default it shows one image in landscape format. Clicking on it will bring up a lightbox and you can you left and right arrows in order to navigate through the post attached media. In order to make this work I am using a GP Element (Hook/PHP) a plugin justified image grid. The definition here fits to the overall container witdh of 1200px and particularly good for images in landscape format. It looks like a featured image, but it works like a gallery. This works very good. Let’s call the solution VirtualFeaturedImage.
The issue I encounter is the following: once the featured image is in portrait ratio the idea of a featured image is broken. The implemented solution is showing the first two images of the gallery. Reason for this is the overall container witdh 1200px. So I cut the gallery to one image what I don’t want.
I am thinking about a solution with a more narrow container width of ~400px when finding a an featured Image in portrait format with the VirtualFeaturedImage and keeping the default container width 1200px in case of a landscape format.
Can you give some thoughts, please?
Thanks in advance, Ernst Wilhelm
–> Some more information via PI -
The theme can NOT control content that are from the 3rd party plugins, I’m not sure what we can help with here.
Let me know!
Anonymous
Hi, dear Ying.
I don’t need any help with the 3rd party plugin. I just thought you would appreciate some background information for better understanding.
I am wondering how can I call a custom block with a container and some php coding inside. What would be your approach?
Many thanks in advance, Ernst Wilhelm
Maybe creating a custom hook to store the container, and create a shortcode for the PHP coding, and add the shrotcode to the custom hook as well.
Anonymous
Hi There. I’ve created a custom block. Is there a json file be stored for these definitions. If so can you tell me where this file is located?
GP does not have a
theme.json
file.Are you trying to call the custom block on the site?
If so, try this method:
1. Add your blocks into a block element – hook, set hook name to
custom
>portable_hook
, set location to entire site.2. Add this PHP code to create a shortcode which can pull the block from the element. Then you can use
[my_portable_hook]
to pull the element.add_shortcode('my_portable_hook', function($atts){ ob_start(); do_action('portable_hook'); return ob_get_clean(); });
Let me know if this helps!
Anonymous
Hi.
Indeed there is a possibility to export the custom block definitions as a .json file.
Lucky me, now I have two options for investigation.I will let you know.
Sure 🙂
