Feature images not being served at correct size
  • Some feature images are not showing at the pre-defined size (medium) on my site.
    I’ve regenerated feature image thumbnails but the problem persists.
    Feature image size is 600×900 and medium is set to 400 x 400 (max)
    What am I missing?
    Your images have different dimensions inherently. This is the reason why their sizes are different. They may be 400px in height for instance, but since their aspect-ratio isn’t 400×400 and their widths are different, the rendered sizes will be different width-wise.
    What you can do is create a Block Element – Content Template so that you’d be able to control how the images look. Reference: https://docs.generatepress.com/article/block-element-content-template/
    You can also control them through custom CSS by adding this through Appearance > Customize > Additional CSS:
    :is(.blog, .archive) .post-image img{
        object-fit: cover;
        width: 400px;
    You can also try defining specific dimensions in Appearance > Customize > Layout > Blog: https://docs.generatepress.com/article/adjusting-the-featured-images/
