Featured Image Size
    I’m wondering if there’s a way to set a standart image size for the featured image. Below you can see the difference on the sizes:
    I generally use images from the web and I dont have time to resize them.
    best,
  • Or in the best cases, you have any size recommendation to use as default?
    ideally you should upload all featured images of the same size and aspect ratio, as this will save you a lot of hassle .
    Otherwise you can force the images to all the same size:
    1. go to Appearance > Elements and edit the Blog/archive loop template element.
    2. Select the Image Block and in its block settings:
    2.1 Set the Image Attachement to Mediu,
    2.1 set the Width and the Height values to what you need, and set the Object Fit to Cover.
    3. Save those changes
  • Thanks!
  • You’re welcome
