Anonymous
I opened a topic and closed, not realizing that the two line menu would also affect the mobile menu.
I figured I would ask 4 questions to keep it concise
1)How can I make the desktop menu two lines, but the mobile menu 1 line?
see screenshots Desktop and Mobile
2)How can I center the words in each menu item? So that the upper and lower words are both centered (on desktop only)
3)How can I make the hover color take up the entirety of the menu on desktop? On some menu items, the hover color only covers a portion – there are gaps on top and bottom. See screenshot Here
4)how can I remove the drop-down arrows? I tried under generatepress menu, but it doesn’t work.
Thank you for your great help, as always!
For #1 and #2, can you remove the <br> tag you added to the menu so we can take another look at a different approach?
For #3 and #4, try adding this CSS:
.sf-menu li:first-child a, .sf-menu li:last-child a { padding-top: 24px; padding-bottom: 24px; } .sf-menu li .dropdown-menu-toggle span { display: none; } -
Anonymous
Thank you, added the .css for #3/#4 and it worked, thank you.
I’ve also removed the <br> tags from all menu items.
Thank you! -
Anonymous
Sorry for some reason i could not edit the last entry.
Added the .css and it seemed to work, but then removed the <br> tags now there is a brown gap at top and bottom of all menu hover items.
Try changing Alvind’s first CSS from this:
.sf-menu li:first-child a, .sf-menu li:last-child a { padding-top: 24px; padding-bottom: 24px; }to this:
.main-nav .sf-menu >li >a { padding-top: 24px; padding-bottom: 24px; }As for #1 and #2, I think you can create 2 menus at appearance > menus, assign 1 menu that includes the <br> tag to primary navigation, and assign the other menu without <br> tag to the off canvas menu.
Anonymous
I created the off canvas menu so that’s fine.
and added the .css you provided. The current tab/color is now short, as are other items in the menu. as in the hover color doesn’t go all the way to top/bottom.
also the words are not centered in each menu item the are aligned right instead of centered.
Thank you.
Anonymous
sorry, meant to say menu items are aligned left, not right.
A lot has changed, so let’s start fresh.
First, remove this CSS:
.main-nav .sf-menu >li >a { padding-top: 24px; padding-bottom: 24px; } .sf-menu li .dropdown-menu-toggle span { display: none; }Then add this instead:
.sf-menu li.menu-item-6491 a .dropdown-menu-toggle span { display: none; } .sf-menu li.menu-item-864 a .dropdown-menu-toggle span { opacity: 0; } .main-navigation .main-nav ul li.menu-item-6021.current-menu-item > a, .main-navigation .main-nav ul li.menu-item-6021:hover > a { padding-top: 24px; padding-bottom: 24px; }Let me know if that works!
Anonymous
unfortunately the words are not centered on each menu – i’d like the top and bottom to be both centered. I guess i could add a <center and </center> code to each menu item? should i do that?
Anonymous
The words are not centered (left to right centered)
I’d like both the first and second line in each menu item to be centered if possible.
Add this CSS as well:
.sf-menu li > a { display: flex; align-items: center; justify-content: center; text-align: center } -
Anonymous
That fixed some of them – some menu items are centered others are not.
Maybe has to do with items not being centered having dropdown menus – or having sub-menu items?
Can you recheck the CSS you added in the Customizer? It looks like there’s a
*character at the beginning of the code that’s preventing it from parsing, which is why it isn’t working. The CSS itself should work once that’s removed. -
Anonymous
That worked, Thank you!
You’re welcome!
