Filtering Looper results by ACF Post Object field based on current post ID
    I’m working on a setup with two custom post types: verkaufsobjekte (real estate objects) and aktuelles (news/updates).
    Each aktuelles post has an ACF Post Object field called zugehoriges_projekt that stores a reference to one verkaufsobjekte post. On the single template of each verkaufsobjekte post, I want to display only the aktuelles posts that are assigned to that specific object.
    **My setup:**
    – GenerateBlocks Pro
    – GeneratePress Pro
    – ACF Pro
    – Field type: Post Object
    What I’m trying to achieve:
    On the single verkaufsobjekte template, a Looper block that runs a query equivalent to:
    `php
    new WP_Query([
    ‘post_type’ => ‘aktuelles’,
    ‘meta_query’ => [
    ‘key’ => ‘zugehoriges_projekt’,
    ‘value’ => get_queried_object_id(),
    ‘compare’ => ‘=’,
    My questions:
    Is there a PHP filter or hook available for the Looper block?
    Is there any other recommended approach within GenerateBlocks to achieve this dynamic meta query without custom page templates?
    Thanks in advance!
    Are you using v1 or v2 blocks? I am asking because the filter name might be different!
  • I am using v2 blocks.
  • I would recommend using the Relationship field instead of the post object.
    You do not need to use custom code; with GB Pro and v2 query block, you can set the query type to post meta > relationship field name, and it will fetch the posts from the relationship field.
