mcgaleti
I am using the Flex Display on this Services Page but I can’t figure out why these 3 boxes don’t have the same height.
I am kind of new with the Flex Concept but I understood that as these 3 boxes’ containers are all inside one Parent Container, they should automatically expand to be the height of the “parent container” ?!
THank you so much.
Yes, you are right, the containers should have the same height by default.
But you added
height:100%
to the child containers, try removing those values to see the results 🙂This behaviour occurs because
height: 100%
on the flex children requires their parent’s height to be explicitly defined in terms of pixels or another non-percentage unit. If the parent does not have a defined height or its height is determined by its content, the height: 100% on the children becomes ambiguous, leading to unexpected results.
