AGTDesigns
I’m using the Kadence Accordion Block to create a FAQ section with the accordion on the left and an image on the right. I have noticed there is an odd issue where when the accordion is closed its a different width than when its opened. At first I thought it was an issue with the Kadence block but if I change the layout options to block or something other than flex/inline-flex in the GenerateBlocks container settings that contains the accordion/image then the issue doesn’t occur.Any help appreciated.
Set the parent container(gb-element-e96f6a1c)’s
displaytogridinstead offlexshould fix the problem. -
AGTDesigns
Works perfect, thank you
