flip shape divider vertically
  • Hi, how can i rotate the shape divider to be a vertical?
    check screenshot and current setting
    Select the Shape block, then under the Effects panel, add a Transform: Scale3D effect and set the Y value to -1.
  • yes i can do that, just wanted a quick button for the same.
  • Sure, we’ll look into that — since the flip horizontal option already exists, it makes sense to add a vertical flip toggle as well.
