Font
    Which arabic fonts does Generate Press support?
    And my second question is how would I add these to a blog post. I don’t want the entire post to be in arabic just some parts. My understanding is the fonts can be changed for the entire post only (but what about if I want to have small sections)?
    GP supports all fonts as long as the correct font file is installed on your site or linked.
    For 2nd question, you can use a text/headline block of GenerateBlocks plugin in your post, then you can select a different font-family for the block.
    Can you provide instructions on how to do this?
  • Nevermind ignore my last post- found it. If the arabic (is paragraph) how would I change the font exceptionally then for that blog post (not the entire post) as it’s not a headline.
  • The paragraph block does not have an individual font family option, you will need to use the headline block of the GenerateBlocks plugin.
