Envolutions
I’ve been using the Font library without issues since it first got released but on our latest website i’m running into issues with the Google font i’ve set not loading on the front-end.
Here you can see the set Inter font in the library:
And here it is set inside the customizer font manager:
But then when i check it with the inspector on the front-end it shows this:
I haven’t run into this issue before and i’ve tried deactivating and reactivating the font to no success.
Can you go to settings > general and check if you are using https for WP address and Site address?
If not, please update it to use https.
Then go to the site library, disable the font, save, then re-enable it, it should generate new URLs for the font files.
Let me know if this helps!
Envolutions
Hi Ying,
The http address was indeed the issue and something that went wrong during setup.
It’s working now, thank you for your help!
Glad to hear that 🙂
