twopines
I’ve added a Google Font via the Font Library.
I then have added typography rules within the Customizer to apply this font to headings (for example).
In the block editor, these fonts aren’t being reflected in the editor while I’m trying to style—seems to be picking up my body font I think?
This makes visual styling near impossible.
I have other sites with very similar setups where the Google Fonts added via the Font Library are reflected perfectly.
Any ideas why this would happen? Thanks! -
I will need to see the issue to investigate the cause as this is not the default behaviour.
Can you provide your site’s admin login? You can use the private info field.
twopines
Added. Thanks Ying!
Your setup seems correct, but the editor isn’t loading the font library CSS for the Roboto Condensed font.
Can you try disabling all plugins except GB, GB Pro and GP Premium to test?
twopines
Thanks for the Ying, turned out to be a very odd combination of caching and browser cache/cookies. All set, thanks!
Glad to hear that 🙂
