Font Library: Google font with Latin Extended subset does not display correctly
    I installed the Google font Libre Franklin via Font Library → Install Google Fonts, with the subset set to Latin Extended. Variants: 400, 700, 400 italic, 700 italic.
    Test page: see below
    Fallback set to serif, system-ui to make the issue visible.
    Observed:
    The text on the page is not displayed in Libre Franklin. Czech text renders in a mix of two different typefaces: letters with diacritics (č, ř, ž, ě, ů…) look different from the rest of the text, which appears in the serif fallback.
    The font files load (HTTP 200, font/woff2), and the browser reports the faces as loaded.
    The generated @font-face rules contain no unicode-range.
    The same issue was reported here: https://generate.support/topic/downloaded-google-font-not-displaying/
    That topic is marked as resolved, but the underlying problem remains. The workaround there was to upload the font files manually. Upload Custom Fonts works fine, no question about that. Install Google Fonts, however, appears to work (the subset can be selected and the font installs), but with Latin Extended selected the font does not display correctly.
    As far as I can tell, the Latin Extended file served by Google does not include the basic Latin characters. I would be grateful if you could take a look at this, or let me know if there is something I may have missed about how the Latin Extended option is meant to work.
    Thanks,
    Alena
  • Hi Alena,
    You’ve diagnosed this correctly, and you haven’t missed anything about how the option is meant to work.
    Google’s Latin Extended subset file does not contain the basic Latin characters. It’s built to be loaded alongside the separate “Latin” file, with each one told which characters it’s responsible for. On its own it has no a, b, c and no á, é, í, ó, ú, ý either — those all live in the Latin file. That’s why your Czech text splits into two typefaces: the carons come from Libre Franklin, everything else falls back to the serif.
    The Font Library’s subset setting only allows one subset at a time, so there is currently no way to install both files through it. Choosing Latin Extended for Czech will always leave the basic characters missing.
    One small note: the missing unicode-range is worth fixing on our side, but it isn’t what’s breaking your page. Even with it added, the characters still aren’t in the file.
    I’ve reproduced this locally and passed it to our development team. In the meantime, Upload Custom Fonts is the right route — the file you upload there is the complete font rather than a subset. You can download the full family from fonts.google.com.
    I’ll update you here once I hear back.
    Thank you very much for looking into this so thoroughly and for reproducing it. It’s good to have the cause confirmed.
    I’ll keep using Upload Custom Fonts in the meantime, and I look forward to hearing from you once the development team has had a look.
    Thanks again for your help.
    Best regards,
    Alena
  • Ok, Alena, I will make a note and let you know when I know more, you are welcome!
