lecbooks
Hello, I went into Appearance and increased the size of my body text from 18 to 20 and now some posts have lost spacing between paragraphs but not all paragraphs. Changing it back kept this error. Any thoughts on how I can increase the font size but correct this issue across all my posts? Thank you.
Hello there,
Font-size shouldn’t be causing that issue.
It’s more of the bottom margin. I think you set the bottom margin to a low value for paragraphs –
p
. Can you check in Appearance > Customize > Typography, and alter that if so?Try settings the Body –
Paragraph Bottom Margin
to a higher value like20px
lecbooks
Yes! Thank you. Should have realized that as that fixed it – and I realize I didn’t do it also in mobile view. Thank you so much for the guidance and settings suggestion. I would have been clueless even though it’s something so simple. Appreciate your quick reply!
You’re welcome!
