Fonts from font library not working
    In my Font Library, I added 2 fonts- Audry for all headings and Robot-flex for body text. Both fonts were converted to WOFF2 before uploading. I added Audrey, where all styles were in this font, then when I added Roboto-flex and assigned it to body, none of my headings show up in Audrey. The headings now look like an old previous font I had but deleted, but my cache was cleared. I disabled and then enabled the fonts in the Font Library to regenerate the CSS, but this didn’t work.
    Thank you- Jerry
    You are using http for the website address and WordPress address. Can you change it to https at dashboard > settings > general?
    Then go to the font library, disable the font, save, then reenable it to generate new CSS.
    Let me know if this helps!
  • That did it.
    Thanks so much!
  • No Problem 🙂
