pstudio
I just migrated my site from a dev server over to Flywheel hosting. The fonts, which were installed via the GP Font Library, were not working correctly. Flywheel support noticed that the theme was referring to the font files on the old server, so I deleted the fonts and re-added them. But there are still issues – the font weights aren’t working correctly, and
Here’s the original site:
https://merc.perceptionsdev.com/Here’s the migrated site:
https://massedresource.org/Here’s a screenshot showing the two side by side (the heavier weight font is the correct one):
https://postimg.cc/MnS0mhbKAnd here’s a screenshot of what my client sent me when they try to access:
https://postimg.cc/cgpt4nF4 -
The font files are still connected to the original site.
Go to the font library, disable the fonts, save the change, then enable the fonts again, this should generate new URLs for the font files.
Let me know if this helps!
pstudio
Awesome! I think that worked. Will confirm with the client. Thank you!
