Footer
    Creating a new footer and had some questions;
    1. How do I center the enitre main container?
    2. What is the best way to reduce space between lines. When I used line height the lines overlap as the screen size is reduced.
    3.Phone number and button – how do I make it look like they are are the same level, right now it looks likw the number is above the button
    4. The three containers, how do I spread them out?
    The password doesn’t work, can you check?
  • Can you try again, that is the correct password (tried it on a different browser)
  • I can access the page now 🙂
    Set the root container’s margin-left and margin-right to auto.
    <p> tag comes with a default margin-bottom, you can set margin-bottom to a smaller value, eg. 10px for each of the text block to override the default margin-bottom.
    1) select the phone number text block, set html tag to <div> instead of <p>, this removes the default margin-bottom.
    2) select the parent container of the button and phone number, set its display to flex, justify-content to center.
    Select the parent container of the Grid (gb-element-a0be9391), set its width to 100%.
  • Awesome, thank you! One last question…on mobile view, how do I get the three Logos in the first container to go in a row?
  • I do not see logos, do you mean the 3 FB icons?
    If so, remove the 1fr from the grid-template-columns field for the Grid block on mobile.
  • Yes, that’s it…big thank you for your help!
  • No Problem 🙂
