Footer Element Misalignment
  • Good morning! On my footer element, the column that is second from the right is not top-aligning with the other two columns to the left of it the way it should. Can you help me identify where I might have a setting or something causing this? I’ve looked and looked, and can’t seem to find it.
  • Added a blank container and that seemed to do the trick, so NM!
  • Glad you’ve figured it out 🙂
