footer in mobile view is not positioned at the bottom of the page
  • Good morning,
    I have a problem on some pages, in mobile view. Footer is halfway or even in some pages it is not even visible
    As per advice I removed the fixed heights and used min-height
    this is the site url
    https://simonecontesini.it/luciana/
    I await your kind feedback
    Thanks in advance
    Simone
    I see you have this CSS on your site to force the footer down on short pages:
    body {
        display: flex;
        flex-direction: column;
        width: 100%;
        min-height: 100vh;
    The problem with that on a mobile device is 100vh includes the phones UI areas so it may result in odd behaviour such as the footer being behind the UI.
    Do you need that CSS ?
  • hi,
    if I remove css, as you can see now, it’s worse, the footer is no longer visible on any page
    thanks
  • You have a container with ID anchor-news, its height is set to 500px, so its content is overflowing, remove that static height value should fix the issue.
  • Good morning,
    even removing the fixed height from the #anchor -news div doesn’t work
    I tried to insert again
    body {
    display: flex;
    width: 100%;
    min-height: 100vh;
    the footer is now above, but it’s not in the bottom area of ​​the page
    I need a definitive solution, I’m in an emergency. Otherwise I have to find a way to make a site without Generatepress
    I await your kind but urgent response
    thanks a lot
    Simone
  • Unfortunately there isn’t a universal method that works for all setups, at least not without introducing potential issues. On mobile devices, especially, you need to account for the phone’s UI areas, which can vary significantly from device to device.
  • So with generate press there isnt’ a possiblity to create a site allowed for desktop and mobile?
    I think it’s impossible you reply
    i have creata a simple container with 2 sub container columns…
  • So with generate press there isn’t a possiblity to create a site allowed for desktop and mobile?
    All our site library templates are customized for both desktop and mobile, one key is not adding static height/width values to blocks, and be careful with content from 3rd party plugins.
    Eg, this content from 3rd party plugin is set to 3708px which causes overflow:
    https://app.screencast.com/VSoc6KPiuZlzV
    Eg. this container is set to width:768px which also causes overflow:
    https://app.screencast.com/XQZTTC6ifEGVe
    GB block is a tool to build layout, but you need to know what you are doing. If you set a container width larger than the viewport, you need to make sure a max-width is set to avoid overflow, or set a smaller and reasonable width instead on mobile, hope that makes sense.
    From my experience, the overflow issue is always caused by incorrect style setting.
  • Ok thank you very so much
  • You are welcome   🙂
