When our footer appears in Google, it looks correct. However, in Bing it’s funky. Can’t figure out what’s going wrong. Any ideas?
Thank you.
Did you manually edit the block?
It looks like you’ve added some funky code which alters the container’s HTML structure:
https://app.screencast.com/42pkDEENuLg7eCan you drag all child containers out of the parent container, remove the original parent container, and replace it with a new container?
That didn’t seem to work. I’m rebuilding the footer in a new element. Will let you know if it is successful.
OK, let me know how it goes!
Rebuilding worked. Thanks for the advice.
Glad to hear that 🙂
