Footer Templates Unavailable : (Add Footer Template)
    I want to add the pre-built template for my site footer, but unfortunately it is not available inside “pattern library”
    Note:
    Previously I was able to add that from the pattern library and use it through elements module, but now a days it has 7 templates examples, which are so simple.
    How do I add the pre-built footer template?
    Regards
    Wali
    If you’re referring to the legacy library, it still can be accessed here:
    https://generateblocks.com/legacy-library/?pattern-category=footer
    Just a note: this legacy library will be shutting down soon, so if there are any patterns you’d like to keep, it’s advisable to save them as local patterns.
