Footer wideget applies strangely to pages other than the main homepage.
  • https://imgur.com/a/hItM3XA
    Deleting cache does not apply. Please help
    Can you provide the site link? You can add it to the private information section if you don’t want to expose it publicly.
  • i’ve added my homepage site address
    you can you add this query var: ?nowprocket to the end of the page URL to disable WP Rocket on load.
    And if i do that on one of your pages eg. https://your-site.com/privacy-policy/?nowprocket then the Footer loads correctly.
    So its an issue with WP Rocket.
    Try regenerating the Used CSS it creates.
  • All pages, including privacy policy pages, are not applicable. So should I apply it to all pages? This is actually impossible because I have to apply it every time I post.
  • you can you add this query var: ?nowprocket to the end of the page URL to disable WP Rocket on load.
    This was simply to demonstrate that the issue is with WP Rocket.
    You do not add the query var to all your URLS, its just to test.
    Instead you need to look at the WP Rocket settings and regenerated the Used CSS
    If the issue persists then you should speak to WP Rocket Support , as they should be able to help you configure the plugin correctly.
  • ty I solved this problem.
  • Glad to hear that
