In a query,I’m trying to format a date which is an ACF custom field of type “date” to french format. I managed to display the field with the loop item : {{loop_item key:date_debut_evt}}. This custom field is “date_debut_evt”.
I’m using this filter :add_filter( 'generateblocks_dynamic_tag_output', function( $output, $options ) { if ( isset( $options['tag'] ) && $options['tag'] === 'loop_item' && isset( $options['key'] ) && $options['key'] === 'date_debut_evt' ) { $datetime = DateTime::createFromFormat( 'Ymd', $output ); return $datetime ? date_i18n( 'j F Y', $datetime->getTimestamp() ) : $output; // "29 avril 2026" } return $output; }, 10, 2 );But I can’t get it to work, the output date is always: 20260429 for example.
Could you help me ?
Eric.
Can you try modifying your code to this?
add_filter( 'generateblocks_dynamic_tag_output', function( $output, $options ) { if ( isset( $options['tag'], $options['key'] ) && $options['tag'] === 'loop_item' && $options['key'] === 'date_debut_evt' ) { // Ensure value is a string like "20260429" $raw = trim( (string) $output ); // Validate format strictly $datetime = DateTime::createFromFormat( 'Ymd', $raw ); if ( $datetime instanceof DateTime ) { return date_i18n( 'j F Y', $datetime->getTimestamp() ); // → 29 avril 2026 (if site language = French) } } return $output; }, 10, 2 );Let me know if this helps!
Hello Ying,
Thanks for that code. I didn’t get a formatted date with it so I put a trace in the filter and it never appeared.
By looking at the trace, I could see that it is not ‘tag’ in the Options array but tag_name.
Now it seems ok, here’s the code :add_filter( 'generateblocks_dynamic_tag_output', function( $output, $options ) { if ( isset( $options['tag_name'], $options['key'] ) && $options['tag_name'] === 'loop_item' && $options['key'] === 'date_debut_evt' ) { // Ensure value is a string like "20260429" $raw = trim( (string) $output ); // Validate format strictly $datetime = DateTime::createFromFormat( 'Ymd', $raw ); if ( $datetime instanceof DateTime ) { return date_i18n( 'j F Y', $datetime->getTimestamp() ); // → 29 avril 2026 (if site language = French) } } return $output; }, 10, 2 );Eric.
George
Hi Eric.
Please, use this code instead:
add_filter( 'generateblocks_dynamic_tag_output', function( $output, $options ) { // Check tag_name instead of tag $tag_name = $options['tag_name'] ?? ''; if ( 'loop_item' === $tag_name && isset( $options['key'] ) && $options['key'] === 'date_debut_evt' ) { $datetime = DateTime::createFromFormat( 'Ymd', trim( $output ) ); if ( $datetime instanceof DateTime ) { return date_i18n( 'j F Y', $datetime->getTimestamp() ); } } return $output; }, 10, 2 ); -
Hello George,
Tested and working ok. Thanks.
Eric.
George
Excellent, no problem!
