Anonymous
My blog page uses a query loop with two columns. The post images are 900×500.
I decided I wanted my first post to span the entire two columns above the rest of the posts.
I created two query loops to achieve this. The first is set to one column, and the second is set to two columns (offset 1)
I need help solving this issue: in the one-column query loop, my image is not wide enough to span the two columns of posts beneath. It is centered, but short on both sides. How do I fix this?
Can you provide the username as well? I can not logging into your site without the username.
Try setting the image’s width to 100%.
Anonymous
Thanks, Ying. My username is below
I didn’t see those changes applied on the page. Could you go ahead and implement them? Once that’s done, we can take a closer look and work on resolving the image width issue.
