Mark529
I have the latest versions of GeneratePress and GenerateBlocks Pro running but the Forms block is not available as an option. It is not visible in Settings to enable it. I read on another post that having V1 blocks enabled caused the problem, but I don’t see anywhere I have V1 Blocks enabled. screenshots.https://postimg.cc/gallery/1gC6dtr
Mark -
Stephan Koenigk
You have to install the beta or rc-2 variants of the GenerateBlocks and -Pro version. Then you have to active the form-option to display (in GenerateBlocks where you also can enable/disable overlay-panels and block-conditions).
Mark529
George
@Stephan Koenigk
Thanks for stepping in!
