Front Page stretch on mobile (chrome browser)
    My front page stretch to the left and too much gaps remain on right side (Mobile Chrome browser) I have checked all the main and inner containers and they are fixed with screen don’t went out of the screen.
    How do i resolve this issue? your kind responsive will save me too much time.
    Regards
    Can you lin us to the page?
    Could i provide the credentials for see what the issue is?
    Just to clarify that i have only stretching issue with mobile (stretch from right to left.
    Yes, you may. Kindly share the login link and the credentials through the Private Information field.
  • Hi Fernando,
    Kindly go through .. . . . .
  • That’s odd. Can you try #1 here to debug: https://docs.generatepress.com/article/debugging-tips/
    It’s recommended to backup your site before proceeding with this.
  • Okay, thank you for the work, I will do, and later on update you here.
  • Actually, could you first try setting the Header – Site Header Element to draft to test? I think that might be it.
  • First, I will check the header element that I activated through (GP Elements) – If my issue resolve than I will update you here.
  • E.g. remove header element and activate simple primary navigation
  • It seems that was the cause of the issue.
    Could you re-share admin login credentials so I can check them? The current shared credentials aren’t working. Re-activate the Element as well.
    I have de-activated the header element – the issue has resolved. Now I have re-activated again and the issue appear again.
    kindly check the private info.
  • The issue is coming from the Shortcode.
    Could you try disabling the Sticky Navigation from the Customizer to test?
  • Thank you for the kind support, the issue has fixed by disabling the sticky navigation.
  • You’re welcome!
    Sorry for the interruption here, my 95% issue has solved. The only issue I have is my Front page is tiny stretching to both Left & Right side across all the page.
    All the rest pages works fine.
Viewing 16 posts - 1 through 16 (of 26 total)
