Full div clickable issue conflicting with position: absolute button
    I’m trying to make a full .service-card container clickable on my homepage (3-column grid layout), based on this guide: https://generatepress.com/forums/topic/making-full-div-clickable/
    The approach works in general, but I’m running into an issue when combining it with an position: absolute; button inside the card.
    Current setup:
    Each card looks like this structure
    – Container (.service-card)
    — Heading <h2>
    — Heading <p>
    — Button (.card-arrow)
    Custom CSS used:
    .service-card {
        position: relative;
    .card-arrow {
        position: absolute;
        right: 44px;
        bottom: 44px;
        z-index: 2;
    .card-arrow::before {
        content: '';
        position: absolute;
        inset: 0;
        z-index: 1;
    And for the full-card clickable behavior I’m trying to use the ::before pseudo-element approach (overlay on the parent container).
    Problem:
    When I apply the full clickable container technique (using ::before on .card-arrow), the clickable behavior stops working correctly or becomes inconsistent.
    It seems the issue happens because the .card-arrow also has position: absolute;
    Expected result:
    • Entire .service-card should be clickable (like a card link)
    • The .card-arrow should remain positioned bottom-right
    Could you help resolve this please?
    Try replacing your CSS with this:
    .service-card {
        display: flex;
        flex-direction: column;
        position: relative;
    .card-arrow {
        margin-top: auto;
        align-self: flex-end;
        content: '';
        position: absolute;
        inset: 0;
        z-index: 1;
  • Thank you, I already fixed it using almost similar method you’ve sent me.
  • Glad to hear that!
