Full Width Block
  • I can’t seem to get the Faq section on this page to go full width on the background container or inner container in this case.
    The issue is that the section has a global style assigned to it, which includes the .inner-container class with a max-width of 1200px. To fix this, remove the class from the section and also remove the max-width value applied directly to the section.
  • Thanks Alvind, that worked. What is the best method for 100% width. I’ve made the inner container 100% width, but should I make it max width?
  • Your page’s content container is set to full width, so all root containers will be full width by default; you don’t have to specify it.
  • Thanks Ying
  • You are welcome   🙂
