Full width GB in Divi
    I have a site I inherited built in Divi that I am transitioning to GenerateBlock/GeneratePress
    In the meantime I have to fix a couple of pages for the client and thought I would bypass the Divi builder to use GenerateBlocks so I don’t have even more content to re-create. Tt seems I can get GenerateBlocks blocks to go Full width and I’ve tried a couple of things in replicating the homepage.
    I put a Preview link of what I built as a test in Div/GenerateBlocks in the private information section below:
    Current HP (all Divi) – https://mycocycle.com
    Thank you!
    The issue is that the container of the theme you are using is not full-width:
    https://www.screencast.com/t/UNlvbfpv
    This is something you will need to check with your theme support.
    Hope this helps 🙂
  • Thank you, this gives me the idea to target the container with some CSS for these pages I need to build in GenerateBlocks while it’s in Divi. Check out the test link and let me know if you think that would be a problem?
    This will be a question for your theme, as the CSS may or may not conflict with your theme CSS.
  • OK, I realize not the best situation. Thank you for your help!
  • You are welcome 🙂
