Full width header
    The header settings are not working. I make the changes to full width, save and when I open it again they are not saved.
    I am using the Spacious website template.
    Spacious has a very unique layout, it has this CSS which adds 5% margin around the body, so even if you set the header to full width, it can only reach as wide as 90% of the screen.
    Unless you remove this CSS from customizer > additional CSS to make the entire body full width.
    body {
        margin: 5%;
        position: relative;
  • Hi Ying
    Your support is very good.
    Issue resolved.
    Thank you very much
  • You are welcome   🙂
