Funky buttons with global styles in GB 2.0
    I am just starting out a new site with GP and GB 2.0. I have a global styles kind of system that I am using to set up all the styles through the site.
    I have my buttons set up with global styles, but when I add the buttons in the editor it seems like the style is getting overwritten is some kind of way and it is getting a underline as well.
    See the first button the first page.
    And here is the button styling:
    .btn {
        background-color: var(--djfdarkgreen);
        color: var(--djfwhite);
        display: inline-flex;
        font-weight: 500;
        transition: all 0.2s ease 0s;
        border-radius: 200px;
        padding: 1rem 2rem
    Go to cusotmizer > colors > content, and remove the link color set there.
    Is that really the best way to do it? If I do that all the links in the content is in wrong colors..
    -J
  • You had another link color set at customizer> colors > body, when I checked your site, the color is the same as the one you set at customizer> colors > content.
    So, which color is wrong? Can I see an example?
  • If I change the colors to white in customizer> colors > content, the links in the paragraphs gets white as well.
    If I change colors here: customizer> colors > body, nothing happens.
  • Does it have something to do with the tag name?
    The proper way is to set your global link color under Customize > Colors > Body > Link. Do not setting a link color under Customize > Colors > Content > Link, as it will override your custom link color.
  • That easy 🙂 Thanks Alvind!
    But the button text gets underlines now, that did not happen with GB 1.X and GP 1.X. Any nice trick to solve that?
  • Added this:
    .btn  {
        text-decoration: none;
    .btn:hover  {
    Is that right?
  • There is an option to remove link underlines under Appearance > Customize > General. Set the Underline Links option to Never: https://cln.sh/rhfybBCX
  • Ah, of course. Thanks!
  • No problem!
