Gallery for products on Niche Starter Site
    for the webshop, we use the Niche Starter Site, and I think this one is not in the library anymore. Back then, when we installed it we had a slider for the images in a product when I am not mistaken, but this is not the case anymore. Can I set that up with GB or does it not work with the Woo-Template?
    Can i access the Niche-Starter Site still anywhere?
    What would be an alternative in your opinion which is manageable with GB to achieve?
    Thank you
    Niche site is not available anymore but you can set up a product image carousel using the carousel block available in GB Pro. You could insert a query carousel and just display the image from the Products custom post type.
