halosorio
Hi Team,
I’ve noticed that a big gap on the right side of my pages appears as soon as I start scrolling.
https://www.nationwideunitedautotransport.com/
I’ve reached out to Elementor and explained what is happening and they informed me that it had to do with my GeneratePress theme.
Please see attached screenshots of issue
Is it only an issue in the backend? As I don’t see it on the front end.
If so, can you provide an admin login so I can see the issue?
halosorio
Hi Ying, Thank you for your response.
Yes, I see it on the front end as well.
Here’s a screenshot from the front end https://postimg.cc/5HHgLXtk
As soon as I start scrolling, a horizontal scrollbar is introduced and then a gap on the right side of my pages
There seems to be a conflict between Elementor and GP’s sticky navigation.
I have disabled the sticky navigation, and the issue seems to be fixed. Can you check?
halosorio
Hi Ying,
Yeup! That fixed it.
So I wouldn’t be able to add a sticky navigation? Is there any workaround for that?
Thank you for your help
You can use this CSS to make it sticky:
nav#site-navigation { position: sticky; top: 0; } -
halosorio
Thank you Ying! 🙂
