jrgong
Hey guys
encountered an issue, how to repro:
Any time I create a new GB button, a unique gb-text-xxxxxx (wherease xxxxxxx is a unique identifier) keeps overriding the gb-button-primary global styles which I apply manually.
Is that expected behaviour? If yes, how can I remove the gb-text-xxxxxx style from the button? -
The
gb-text-xxxxxxis a local style, so if a block has both a Global Style and a Local Style, the local style will override the global style.After applying a Global Style to a block, you’ll need to clear the local block styles: https://cln.sh/pl5p4hH1
I recommend saving the block as a Pattern so you can easily add it to your page whenever you need that specific styled button.
jrgong
ah thx, missed that block style. Where can I edit block style CSS? Could not find any info in the docs.
The local block style CSS cannot be edited. It is the default styling applied when you first add the Button block inside the editor.
webfresh
some info here that may help:
https://generate.support/topic/gb2-0-0-beta-2-how-to-make-button-defaults-show-in-backend/#post-143442
