GB blocks serialization MCP
  • Goal I’m aiming for: converting any HTML into GenerateBlocks.
    Challenge: Converting one line at a time, especially in large files with more than 3,000 lines, causes the LLM to hallucinate, lose focus, and start taking shortcuts due to the repetitive nature of the task.
    Ask: I was wondering if there’s a way to create either an MCP or an API to directly use the plugin’s serialization to create and convert the blocks I need.
    We do not currently provide an official or native implementation for that specific workflow.
    As a possible workaround, you could provide the LLM with the GenerateBlocks plugin source code so it can analyze the block architecture and settings schema directly. However, this type of integration usually requires multiple iterations of prompt refinement and output validation, so it is unlikely to produce reliable results in a single pass.
