.gb-container vs .gb-element-id
  • Hi team,
    in my style.css I have a CSS instruction that is often used and is very helpful.
    /* remove bottom margin on last paragraph or list in container */
    .gb-container p:last-child:last-of-type,
    .gb-container ul:last-child:last-of-type {
      margin-bottom: 0px;
    Unfortunately, it no longer works with v2 🥴
    There is no more .gb-container. Instead, the containers are now suddenly called .gb-element.
    I can’t use the CSS because .gb-element no longer exists as a single class. It is now always associated with an id.
    What can I do to replace the CSS, so that it works with v2?
    Thank you!
    You can use
    [class^="gb-element-"]  p:last-child:last-of-type, [class^="gb-element-"] ul:last-child:last-of-type {
      margin-bottom: 0px;
    Or create a global style for it.
  • Thank you very much, Ying, that helps 👍!
    Unfortunately, I have a similar problem with the buttons.
    I used to address the buttons with .gb-button, but this class no longer seems to exist.
    Instead, the buttons now have the class .gb-text, right?
    But don’t all paragraphs also have the class gb-text?
    How would I then convert this style to v2?
    /* GB button line height override */
    .gb-button {
    	line-height: 1.5em;
  • Yes, button is the same as text block, only with tag being a instead of p, h1, h2 etc.
    You can use a.gb-text to target the button.
  • Yes of course, that’s it!
    Thank you !!
  • You are welcome   🙂
