tampoppie
When I change the Container Link “open links in a new tab” toggle to ON, then save the post, it doesn’t work. When I click the link it does not open in a new tab. I went back into the link config to see and noticed the Container Link “open links in a new tab” toggle reverted back to OFF.
Screenshot: https://drive.google.com/file/d/10ba0bleBmOcb4PHMv1zrlXPrAxMwUY9o/view?usp=sharing
I can not replicate the same issue on my site.
Are your GB and GB Pro plugins up to date?
If you create a new container, and set up the container link, does the issue happen too?
tampoppie
Yes, the plugins are up to date.
I created a new container and setup the link as you requested and it worked fine.
I noticed something with the container links that aren’t working (“open links in a new tab” keep reverting to off. If you look at the list view on the left you’ll see the GB button is surrounded by a dashed line box. Check out what I mean out here: https://drive.google.com/file/d/1mXRe-0rzxxHQ-1YTMQaMaPOQWmcEr1xO/view?usp=sharing
Hi Tampoppie,
I see. That seems to be the old Buttons Block. Do you have a lot of Buttons acting this way?
One thing you can do is to recreate all those Buttons.
Since you have GB Pro, you can create a Local Pattern for the Buttons so that you can add them easily.
