digitera
Pro user, but I let my licence lapse before renewing it again, meaning the licence key was changed on me. I’m trying to insert the new key, but keep getting an error, as per this screenshot. Any suggestions on how to fix?
Can you check this doc and let me know if it helps!
https://docs.generatepress.com/article/license-key-activation-issues/ -
digitera
Nothing worked.
1) SAVE isn’t the issue, as I was able to save an empty licence field.
2) I never saw 403 error, just the red error from the screenshot.
3) I tried adding the Secondary API code snippet to functions.php, to no effect.
4) I checked for cURL, and that was already enabled.
5) I’m using CloudPanel, and there’s no blocks there. However, this server is on AWS, so let me know if I have to open a port there.
digitera
Actualy, I was able to get the licence saved properly by inserting the code snippet for Generate Blocks as opposed to Generate Press….so that issue is solved now.
New issue though. I don’t see the Pro patterns from the following link available to me in the backend.
https://generatepress.com/pattern-library/
Can you advise on how to get them viewable in the Block Editor please?
Are you still using V1 blocks?
If so, most newer patterns are only available for V2 blocks. To access the full pattern library, you’ll need to switch to V2 blocks: https://learn.generatepress.com/blocks/block-guide/generateblocks-1-x-to-2-0/
