I’m using Query Loop to show pages. But I cant set order view (it’s showing most recently first). Any way to order using the default pages order on wordpress?
Thank you
Are you referring to the order option in the page quick editor?
https://wordpress.org/documentation/article/create-pages/#using-the-quick-edit-option
Let me know! -
Hi, Ying
Yes!
I see.
In this case, try the solution below:
1. Add an additional CSS class to the Grid block of the query loop block, eg.
order-by-menu-order.2. Add the below PHP code:
add_filter( 'generateblocks_query_loop_args', function( $query_args, $attributes ) { if ( ! is_admin() && ! empty( $attributes['className'] ) && strpos( $attributes['className'], 'order-by-menu-order' ) !== false ) { $query_args['orderby'] = 'menu_order'; } return $query_args; }, 10, 2 );You can use one of the methods mentioned in this article to add PHP code:
Let me know how it goes 🙂
Hi, Ying
It actually works. But I would like to reverse the order.
For example I have set: 1, 2, 3, 4
But it’s showing: 4, 3, 2, 1I think I’m doing everything right
in the Query Loop you can Add Parameter:
1. Order By -> Menu Order
2. Order -> DESC or ASC depending which way you want them
Works!
Thank you, David. -
You’re welcome
