GB settings display issue since new update
    Since new update, apart from the fact that I have more than 400 articles using the old version of the blocks and I don’t know how I’m going to update them without spending my life doing it (I really didn’t need the extra work), the sidebar with the block settings is totally messed up. For example in the attached image you’ll see that you can’t see anything when you want to add a size in the Sizing tab :
    Picture of Sizing Tab messed up
    Thanks for your help,
    Samuel
    sorry if the updates have causes some frustration.
    To note, you do not have to update your legacy container blocks, they will work just fine as is and that will not change even with future updates.
    The sidebar sizing tab, that is odd. Is this on any particular browser ?
    The sidebar issue is on all browsers.
    I’ve been working around, and it happens that it’s a plugin that is causing this conflict : https://daext.com/hreflang-manager/
    This is weird because this plugin is just adding href tags in html code and that’s it. It’s pretty lightweight plugin.
    What could be the conflict here ?
    I’m going to contact the plugin support, but if you could have a look as well it would be appreciated.
    Thanks a lot,
    Samuel
    Update : the plugin support will release an update to fix the conflict (CSS related).
    Regards,
    Samuel
  • Glad to hear you found the issue.
