What happened to the target box when adding effects in the GB2.0? I want to target the background image of a div when hovering and another effect on the inner container.
With GB Pro, you can create any custom selectors.
Can you specify what hover effect you want to add to the background image and the inner container?
Translate on the inner container and zoom on the background-image. I tried adding custom selectors like background or background-img etc. but these are not working. I am doing it through css now but it would be nice to keep it simple in the block editor like it worked before.
Background image does not have anything to be targeted, they are attached to the container itself.
In your case, you need to create a pseudo-element (
:before
or:after
) to attach the background image.
Try following the steps below:1. Select the Container Block, set its
Position
toRelative
, remove the background image.2. While the container is selected, click the More button at top right of the right sidebar, click + New button, select
:before
, and compound the selector. This will set the selector to:.gb-element-xxxxxxxx:before
.3. For the new selector
, setposition
toAbsolute
, and theTop
,Right
,Bottom
andLeft
values to0
, content to""
.4. Now you can attach the background image to
, addtransition
to it.5. Create a new selector
.gb-element-xxxxxxxx:hover:before
, and setscale
to1.05
in the effect panel.For the inner container that contains text content,
1. Set
position
torelative
,z-index
to1
.2. Add a class to the inner container, eg.
slide-container
Adding CSS class(es): https://wordpress.com/support/wordpress-editor/adding-additional-css-classes-to-blocks/3. Select the outer container, create 2 new selector:
.gb-element-xxxxxxx .slide-container
and.gb-element-xxxxxxx:hover .slide-container
.4. Add the
translate
effect to.gb-element-xxxxxxx:hover .slide-container
, and addtransition
to.gb-element-xxxxxxx .slide-container
Thanks, but the old way was way easier 🙂
I know, the old way was not ideal, but we will be adding some shortcuts to the UI 🙂
