GBP 2.5 alpha – Is it now possible to rename Global Styles?
    I’m aware that renaming a global style is already possible.
    However, the warning says: “Elements and blocks using this class name may lose visual styles after this change.”
    Does this mean that in version 2.5, after renaming a global style, I still need to manually re-apply the updated style to all elements that are using it?
    Kind regards
    Sascha
  • Hi Sascha,
    Yes, that’s correct. Unfortunately there are no changes regarding that.
  • Would it be possible to rename via database/SQL “search replace” kind of query?
  • Unfortunately, I’m not sure, but you can give it a try on a staging site.
