Generate press theme not rendering correctly
    I am currently using the on my website but it does not seem to render correctly – I have tried removing the imported site and importing it again but it does not seem to work.
    Can you remove the imported template, then disable all plugins except GP Premium and GB, try import the template again?
    Let me know if this helps!
  • Hi this is now working thank you. Once this is done can I reactivate the plugins I have installed?
  • Yes, you can 🙂
