generate press update failed
  • takkularapsis
    I have multiple sites built with gp and gp block.
    Problem comes when sometimes trying to update plugin, it says failed.
    And if i go to plugin settings ( remove and add licence key again ), then the update is success.
    Problem is, it is time consuming to do this with every site.
    updating the GP Premium plugin and GB Pro plugins requires authorisation from our servers, sometimes that is not possible and that may be related to a number of factors outside of our control such as firewalls or curl permissions on a server.
    IF re-adding the license resolves the issue then can you check if your have authorised the site URL in your account – see here for more info:
    https://docs.generatepress.com/article/authorizing-site-urls/
