generateblock remove container condition
  • Hi. MR.GP
    I can’t find the “generateblock remove container condition” feature in GenerateBlocks 2.0.
    I searched about it, and it seems it has been removed. Is this true?
    I really need the functionality to conditionally remove or hide a container based on certain conditions. Specifically, I need to control container visibility based on whether an ACF field has a value or not.
    That option no longer exists—it was part of GP Premium but hasn’t been included since GB 2.0. We’re working on it.
    In the meantime, we can use a custom snippet to achieve the desired condition. Let us know if you need assistance with that.
  • liquidonthedrums
    Hi Alvind,
    I would be interested in seeing how you implement this functionality with GB 2.0 (via custom snippet)
  • Hi @liquidonthedrums,
    If you have specific conditions for hiding the block (e.g., when a custom field is empty or returns a particular value), let me know so I can draft a tailored snippet for your requirement. 🙂
  • liquidonthedrums
    My use case is to hide a container if an acf checkbox is ticked (ie. value=1).
  • 1. Add a CSS class to the container, eg. custom-condition-container.
    Adding CSS class(es): https://wordpress.com/support/wordpress-editor/adding-additional-css-classes-to-blocks/
    2. Add this PHP code, and change checkbox_field_name to the actual one:
    add_filter( 'render_block', function( $block_content, $block ) {
        if (
            ! is_admin() &&
            ! empty( $block['attrs']['className'] ) &&
            strpos( $block['attrs']['className'], 'custom-condition-container' ) !== false
            $checkbox = get_field('checkbox_field_name');
            // If checkbox is true, return empty string (hide block)
            if ($checkbox) {
                return '';
            // If checkbox is false, return original content
            return $block_content;
        // Return original content if conditions aren't met
    }, 10, 2 );
  • liquidonthedrums
    Hi Ying,
    Thanks for the response. Looks great!
  • You are welcome   🙂
