chaoscontrol
Issue started immediately after updating to WordPress 7.0.
Environment:
* WordPress 7.0
* GeneratePress (latest)
* GenerateBlocks (latest)
* GenerateBlocks Pro (latest)
* ACF Pro (latest)Problem:
In the block editor, interacting with GenerateBlocks buttons causes editor errors and blocks sometimes display “This block has encountered an error and cannot be previewed.”Native/core WordPress Button blocks do NOT trigger the issue.
The issue also occurs on posts/pages that do not contain any custom ACF blocks, so this appears unrelated to custom PHP render callbacks.
I tested:
* clearing browser/server/CDN caches
* updating all GeneratePress/GenerateBlocks plugins
* newly-created GenerateBlocks buttons (not just older content)
* posts without custom blocksThe issue still occurs.
Console error:
TypeError: i is not a function
at n (components.js?ver=%5E1.2.0:4:5549)The stack trace points to:
/wp-content/plugins/generateblocks/dist/components.js?ver=%5E1.2.0
and also loads:
/wp-content/plugins/generateblocks-pro/dist/components.js?ver=%5E1.3.0
This appears to be a React/editor-side issue related to GenerateBlocks components under WP 7 / React 18.
Please let me know if there is a known compatibility issue or debugging step I should try.
chaoscontrol
Following up – something that is consitently causing it is changing the background color. I initially encountred it on a button, but then it also happened on a container. With the buttons I was able to change the font weight and color without it happening.
Is it possible for you to provide a temporary admin login to the site so we can take a closer look?
It would also be helpful if you have a staging site available, so we can safely perform debugging and testing if needed.
chaoscontrol
After troubleshooting further, I realized I still had SocialWarfare Pro enabled and THAT was the cause of the conflict/issues. It works fine after disabling.
Glad to hear that! 🙂
