Oliver
Hello Support-Team,
I’ve recreated the issue on a fresh WordPress 6.5.3 installation.
These are the changes I did:
Theme installed: GeneratePress 3.4.0
Modules activated: Blog and SpacingPlugins installed: GenerateBlocks 1.9.1, GenerateBlocks Pro 1.7.0, GP Premium 2.4.0 and Yoast Duplicate Post.
GenerateBlocks Settings -> CSS PRINT METHOD -> Inline Embedding
Appearance Customize – Use infinite scroll
I’ve created a post Test A containing a grid, a container, an image and a more element.
Grid: HORIZONTAL ALIGNMENT Center
Container: GRID ITEM WIDTH (%) 50
Image: HEIGHT 300px, OBJECT-FIT Contain
Then I’ve created a new post Test B and copy all elemenents from Test A. The result is, Test B contains all the IDs from Test A.
Adding background color and border to Test B
For each post the IDs are unique but not in blog mode
Test A shows the styles from Test B now
it’s a known issue, the copy and pase function can only regenerate unique classes on the same page. And as yet there is no solutiun for this:
To get around that Duplicate, then CUT and PASTE between the posts. The duplicate option generates a new class on the fly.
Oliver
Hello David,
my post is actually not related to the copy and paste function. It’s related to the style tag rendering on the blog page, like my other post “GenerateBlocks – style tags are missing on blog page”. Because in this case, an earlier post (Test A) reuse the style tags from the later post (Test B). I understand that at the end it’s a problem caused by the user itself, but I don’t think that a default user is aware of this.
I’ve searched the GenerateBlocks documentation for “copy” and for “paste” and couldn’t find any information regarding this issue.Oliver
The COPY and PASTE issue resulting in duplicate classes isn’t related as such to the other issue ie. the missing style tags.
Which i replied to here:
https://generate.support/topic/generateblocks-style-tags-are-missing-on-blog-page/#post-108789I’ll add some more info to that reply i a moment.
The COPY and PASTE issue generally only shows up in support topics where users have copied blocks from a Post to a GP Element, where both instances of the block would be seen on the front end.
